F8 R/T
Discussion in 'New Member Check-In' started by F8Vendetta, Jun 24, 2019.
    305/35/20 on the 10.5 wheels will look aggressive and have less chance off rubbing
    F8Vendetta likes this.
  2. F8Vendetta
    F8Vendetta Full Access Member
    Awesome, thanks for the suggestion! I'll likely go with that then. Any suggestion for the front?
    275/45/20 will fit with no issues as long as the offset is right on the wheels. The spindles are different on the scat pack vs. r/t so the scat pack has more room.
  4. F8Vendetta
    Ah gotcha, I'm not exactly sure about the offset... But I do know which rims I'll be getting. I know I'll need an alignment, but I'll likely need to work on the camber as well to get it as close as I can to normal specs right? I don't want to go through tires too quickly
    Yes unless you like the negative camber look. I didn’t like it so I spent the money to fix it but as you saw from my thread it gets expensive
    What wheels. I can tell you that the oem 20x9.5 wheels have +18 mm offset so if you get close to that you will be good. Too much more positive offset and that’s where you will have issues and need spacers
  7. F8Vendetta
  8. F8Vendetta
    The front at x9 would be 15mm
    But the rear at 10.5 would be 20mm
    Maybe 20x9 and 20x10? Both would be at 15mm offset, but will that even look as good or noticed at all? Lol I always see people with chargers so 9.5 and 10.5 on width
    Guess anything could be better than my stock since it's x8
    Yes and with the offset on those 20x9's it will look a lot better because the wheel won't be tucked in so far.
    those 20x9 wheels will work with 275/40/20 with no rubbing and no spacers(in my post before I accidentally put 275/45/20 which is incorrect)
    with those rear wheels and 305/35/20's you definitely shouldn't need any wheels spacers to prevent rubbing on the inside.
  10. F8Vendetta
    Dude you are the man, so definitely go with the 20x10 right? Just to clarify
